cattortoise's avatar
Dec 23, 2021
How to disable WPS?
I am trying to disable WPS on a XR450 Nighthawk Router, but I do not see an option to do so. The only WPS settings I see is through the 'WPS Wizard' section. Where is this setting located?
  • I believe if you have Smart Connect enabled then WPS is disabled, if you don't then there is no specific way to disable it as far as I am aware.
    • cattortoise's avatar
      cattortoise
      Tutor
      I dont think that really disables it.  I have Smart Connect enabled and when I connect to my WiFi using a new device, I get a message saying to enter the password OR press the button on my router.    Its pretty disappointing that Netgear does not give the option to disable such a feature, especially since its such a poor security standard (and security issue).
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        I'll request that Netgear adds that ability for you but it's not a guarantee they will do so
