immuda
Mar 30, 2023Tutor
Ipv6 What option should i choose?
NightHawk XR1000 Gaming router
XR1000 1.0.0.64_1.0.49
I am on Etisalat (my internet provider), i need to enable IPV6 so that i need to know which option should i choose so that Ipv6 is enabled.
Hi NotFox,
Did you use this driver version?
https://kb.netgear.com/26927/WNA3100-Software-Version-2-2-0-4-Supports-Win8-8-1
I would ask the ISP, the ISP should have this information.
- My ISP says ask netgear
I guess try AUTO.
https://kb.netgear.com/24006/How-do-I-set-up-an-IPv6-Internet-connection-on-my-Nighthawk-router
https://kb.netgear.com/24012/How-do-I-set-up-a-fixed-IPv6-Internet-connection-on-my-Nighthawk-router
Be sure the ISP provides native IPv6 support. Again they should have this information. Modes depends on what the ISP puts out. Not what the router can do. It depends on what the ISP configures IPv6 for there services.
