Reply
Low Ping on speed test, but high ping on gaming
Hypheyy
I just did a speed test on my gaming laptop and it says I have a 15 MS ping, but when I go to play Call of Duty for example it says I get like 70 MS.. If anyone can help me with this situation that would be greatly appreciated since I spent a bit of money on this, Thank you!
Message 1 of 13
Hypheyy
Re: Low Ping on speed test, but high ping on gaming
I also got a new modem (Aris Surfboard SB6190) thats hooked up and everything and I also play on Xbox One
Message 2 of 13
velloonythedeit
dont buy the Aris Surfboard SB6190. what are your upload and downloa speeds?.
Message 3 of 13
Hypheyy
65 Download and 5 Upload
Message 4 of 13
Hypheyy
Anyway I can fix this orrrr?
Message 5 of 13
velloonythedeit
who is your ISP, and yea it is.
Message 6 of 13
Hypheyy
I have Charter Spectrum for my ISP
Message 7 of 13
velloonythedeit
what are your default dns on the xr500 and look through the lists to find the closest or dns to your state here https://sites.google.com/site/kiwi78/public-dns-servers. but make sure to use ping plotter to see your latency on the dns. i also have charter, my ping used to be an 70, then i change modems that drop me down to a 40, and just a few days ago im at an consisted 20 ping but i dont know why?. im in st.louis,mo.
Message 8 of 13
Netduma-Fraser
NetDuma Partner
Are you getting this game ping from the Geo-Filter or the in game ping? Is your Geo-Filter setup with the CoD profile?
Message 9 of 13
velloonythedeit
and no, not the cod profile. im on the xr500.
Message 10 of 13
velloonythedeit
Message 11 of 13
Netduma-Fraser
NetDuma Partner
I'm talking to Hypheyy who is the one having the issue
Message 12 of 13
Tigsman
Tutor
Arris SB6190 is the Puma6 chipset, which if I recall correctly, is under a class action lawsuit for its lack of performance (high pings) during gaming.  Might want to try the Netgear CM600, I beleive it uses a different chipset AND compliant with 400MB speeds for Spectrum.
p.s. still getting 60Mbit?  most parts of the country were upgraded to either 100/10 or 200/10 as base speeds.  You may have as i did, still have some old cat5 patch cables hindering performance.  Might want to to check that too and get Cat6 or better.
T
Message 13 of 13
Discussion stats
  • 12 replies
  • 6516 views
  • 0 kudos
  • 4 in conversation
Announcements
