× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Netgear XR500 Unnamed devices poping up
TheRealOC
Apologies for the repeat of an earlier post, but I'm still having the same problems with my XR500.
I hadn't checked in on routerlogin.net dashboard for a few months, and when I checked the Device Manager, there were a lot of 'unnamed devices' that I didn't recognise.
I went around the house and made a list of wifi-enabled devices we have, and checked them off against the devices that were showing up on the routerlogin.net dashboard (I didn't check using the IP/MAC address but most of the devices in my house have names that were imported from their individual device settings - for example, my iphone was called MYIPHONE7). So I was able to confirm that none of these 'unnamed devices' on the dashboard corresponded to actual devices in the house.
So I figured that they were probably guest devices that had logged onto the wifi network over the last number of months, so I deleted most of them. However, I ran into two problems:
1) There were 2-3 of these 'unnamed devices' actively logged onto one of the wifi networks so I got an 'Unable to delete device beccause it is online' error message when I tried to delete them (even though again - none of these corresponds to actual physical devices in the house)
2) When I checked back in a few hours later, there were several new 'unnamed devices' in the offline section of Device Manager. I switched the XR500 off and on again, but this did nothing.
There are currently 10 unnamed devices, of which 7 have the same first six digits in their MAC addresses - the other three share a different first half. None of the unnamed devices share the first half of a MAC address with any of the actual physcal devices that I know should be there.
Can anyone please advise on how to fix this problem?
Many thanks
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 9
Accepted Solutions
schumaku
Guru
Re: Netgear XR500 Unnamed devices poping up
There are no secrets on a MAC address...
The ones with an OUI starting with 02:xx:xx (like any x2:.., x6:... xA:..., or xE:... are local managed MAC, not assigned to a vendor, freely usable, just unique on a LAN, used by VMs, wireless access points offering multiple SSIDs/VLANs. Look there  -> https://en.wikipedia.org/wiki/MAC_address#Universal_vs._local
For the other random ones, say thank you generation tin hat, say thank you Apple (-> Use private Wi-Fi addresses in iOS 14, iPadOS 14, and watchOS 7 [with complete ridiculous enforced defaults!]), say thank you Android (-> Privacy: MAC Randomization [with smart defaults of course]).
Needless to say - there is no reason to randomize MAC addresses on a home, private, or business network. A correct hardware MAC key for access control, base line security, .... So disable this **** on the network connection settings (by each SSID).
So we can blame Netgear for many things - regardlss on how many times you factory reset your router. Can't see a Netgear problem here...
PS. For those hyping Apple for a "great" privacy innovation - Android has this feature  since Android 8.0 Oreo (API 26, August 2017) - and it never caused (m)any issues.
Message 4 of 9
All Replies
schumaku
Guru
@TheRealOC wrote:
There are currently 10 unnamed devices, of which 7 have the same first six digits in their MAC addresses ...
And the first part of thes MAC addresses are ... ?
Any iOS 14, iPadOS 14, and watchOS 7 systems on your network - your own, or guests?
Message 2 of 9
TheRealOC
Thanks @schumaku
PMing you the MAC addresses now; there are two iPhones running IOS 14 on the network.
Message 3 of 9
schumaku
Guru
Message 4 of 9
TheRealOC
Apologies for the stupid question, but do I disable this **** on network connecting settings in the router's dashboard, or in each individual device?
Message 5 of 9
schumaku
Guru
Hey, no problem! Perfectly understand the confusion caused by this "feature" - and even more the real issues araising where MAC based ACLs are in the game...
Message 6 of 9
schumaku
Guru
@TheRealOC wrote:
... do I disable this **** on network connecting settings in the router's dashboard, or in each individual device?
On each device, and for each SSID/Network connection configured for your home or business networks.
Message 7 of 9
TheRealOC
Is there any way to change the Network Map in Device Manager to a list layout? (The map is getting a bit unmanageable at this point...)
Message 8 of 9
Netduma-Fraser
NetDuma Partner
Click the 3 line icon in the top left of the panel to change it to the table/list view.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 4019 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
