- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear XR500 on Plusnet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please help. I've just set up my New Netgear XR500 on Plusnet. Seems to be working but cannot disable the WiFi on the Plusnet router so now have two devices giving out WiFi. Anyone got any ideas?
Many thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear XR500 on Plusnet
Hi.
You have to log into the plusnet router via it's login interface and disable the wifi. This is a link for the types of routers plusnet use. I hope 1 of these will solve your wifi issue. https://www.plus.net/help/broadband/router-user-guides/
Alternatively you could ring their customer service number and 1 of their advisors will talk you through it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you have a hub one, that defeinate;y cant be used in bridge only mode. You can get a Netgear Modem pretty cheeply, or pick up and old BT openreach modem, tenner or so off ebay, but I would go with the netgear modem as its much newer. There are other modems like the Vigor 130 but that is much more expensive and runs quite warm too.
https://www.amazon.co.uk/NETGEAR-DM200-100EUS-High-Speed-Broadband-Modem/dp/B01GL3YPHI
- Mark as New
- Bookmark
- Subscribe
- Permalink
http://www.argos.co.uk/product/5728882?storeID=4162&cmpid=GS001&_$ja=tsid:59158|cid:598893978|agid:2...
There were also a couple of recent reviews on amazon on the Dm200 that put me off as well. One saying that it wasn't compatible with their netgear router & one saying the setup is fiddly.
I'm going to give this argos one a go & if it fails I'll try & return it and get the Dm200.
Many thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thats a modem router again, which will need putting in bridge mode to work, should be fine though. Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The HG612 is getting a bit long in the tooth but they do work well, I'm on an ECI Cab and my line likes the ECI version better by about 7Mbps, which is a nightmare as it needs a hardware hack for stats. If you do grab a HG612 get a 3B version, the others had issues with overheating, also make sure as BIG_DOG said its been updated to the latest firmware to support G.inp and also so you can get stats off it if you want them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just to add - I assume you are trying to turn off the WiFi to prevent interference with the XR500? If so, you could try swtiching the plusnet router to something less used like channel 2 and make sure the Xr500 is on a different channel e.g. 11. Then see if the XR500 WiFi is everything you expect. If so, it will save you having to spend £30 or so on a new modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The TP-Link router you purchased will handle the pppoe connection for you, theres no need to insert the pppoe login into the xr500 dumaOS at all. Disconnect the xr500 from the tp link and connect your pc/laptop to the tp link lan 1 port. Do a factory reset of the tp-link and set it up via your laptop and follow the on screen prompts and when you get to the screen where you select your isp info insert your pppoe details and complete setup. Once completed make sure to disable wifi and upnp on the tp link. Disconnect pc/laptop from lan 1 and connect the xr500 then your laptop to lan 1 and an ethernet cable from lan 1 of tp link into wan port of xr500. Then, plug power cord back into xr500 and do a factory reset via pinhole at rear but make sure you press it in for 30 seconds to do reset. Once the reboot cycle has completed you should be able to configure the xr500 as you want. You will have to take a note of your xr500 ip address and log into the tp link router and insert that ip address into the dmz of the tp link!
- Mark as New
- Bookmark
- Subscribe
- Permalink
after my last comment i spotted you said cannot connect to tp link via wifi once you put it in modem only mode. You cannot, it has to be connected via ethernet to the tp link in order to get a connection and theat will allow you to get internet access via the xr500. You can then do pppoe that way through the xr500 or use the method in my last post which most users with a modem/router use! Don't want to confuse you just give you connection options as you have 2 to choose from!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now have TP-link in modem mode, the two WiFi frequencies and the PlayStation is working via ethernet. Just need to sort the Duma settings now.
One thing you mentioned that I didn't do is put the address from the XR500 into the TPlink. Do I still need to do that?
Many thanks for your help & patience with me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it is all working for you now and you are up and running. If you need any further help just give a shout.
- Mark as New
- Bookmark
- Subscribe
- Permalink
User | Count |
10 | |
9 | |
6 | |
5 | |
2 |
