zcg4755's avatar
zcg4755
Network Keeps Dropping 2.4 GHz (XR1000)
We had a power outage a few days ago, and ever since then, we haven't been able to access our 2.4 GHz network. Our 5 GHz network works fine, and our ISP confirmed that the modem is working as intended.
I can no longer access the NETGEAR app on my phone. If I click the icon, it starts to load, but then immediately sends me back to my home screen. What should I do?! Thanks.
  • FURRYe38's avatar
    Can you access the routers web page at 192.168.1.1 with a PC and web browser?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    is Smart Connect enabled or disabled on the router?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
    Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
  • Good advice above, I would suggest unplugging it from power for at least 10 minutes to let the residual power drain then try again/try the above.
