JohnWalkden's avatar
JohnWalkden
Nighthawk XR 500 slow wifi speeds
I have an XR 500.
The modem is the virgin V3.
The app speeds im geting are 376  download & 36.96 upload.
When i run a wifi speed checker i get download 22 & upload 32.
Ive changed he channel to 11.
What else can i do, pse keep it simple as im no expert.
Ta
John
  • Are you using Smart Connect? If so disable this and connect to the 5GHz network instead, do you get faster speeds this way?
  • I changed from smart and it seemed ok, it seems it not to be sending out a WiFi signal. Although the speed test through the app is good.
    CO fused.
