ozkan87's avatar
ozkan87
Nighthawk XR300 VPN Drop Outs
I just purchased a new Nighthawk XR300 and my Cisco VPN anyconnect client keeps on dropping in and out when connecting on DTLS protocol. If my connection randomly connects on TLSv1.2 then the connection is stable. How do i know the router is the probelm, well because 2x of my netgear routers behave the same and when I use a cheaper branded modem it works fine. I also create a new network adaptor on my Win10 machine using PPPoE to connect to my ISP direct and the connection is stable completley bypassing everything.
Can Netgear please investigate as to why VPN connections would be dropping out. I did some reasearch on this community page and it looks like I am not the only one who is having issues with Cisco Anyconnect client dropping every 5-10 minutes while using a netgear router.
