NiwaStanley
Jul 19, 2019Aspirant
Phillips Hue Bridge RED LIGHT on XR500
Hello, owner of the XR500 for 5 months now (Damn). I just bought Phillips hue bridge + bulbs from Prime Day (Weee $450~), I tried to connect the bridge to my phone but failed. I've read other posts that other people are having the same problem. But I have one difference so far that the Ethernet led turns red.
Another post with the same problem
- Hue bridge connected by Ethernet to Port #2
- Ethernet LED indicator = RED
- Phillips Bridge has all 3 solid blue led
- Tried setting up Hue with Phone
- Spamming "Press to pair" but nothing registers, tried restoring to fac. setting, turning off and on did not work
- Using the work around that was mentioned in another post, booting up my old tp-link router and connected the hue on it and it works ;l
My router is on Router mode using PPoE for Centurylink. Latest firmware. Port forward 3000 with statc ip did not work.
Apparently this has been a problem for a year and starting to regret buying the XR500 due to a problem with a webserver proxy (separate problem and had to do another work around) and now problem with Phillips Hue Bridge ;l
Be sure the LAN cable is of good working quality between the router and this HUE device. CAT6 is recommeded.
Review the XR routers user manual for LED color indication behaviors.
IS the LED RED or more Amber, a dark orange color?
- NiwaStanleyAspirant
According to the manual:
Solid amber. The router detected a 100 Mbps or 10 Mbps link with a powered-ondevice.
- -Donovan-Luminary
NiwaStanley wrote:According to the manual:
It's normal and I have the same LED amber color on my XR700 because it's a 10/100 ethernet port on Philips Hue Bridge v2.0.
- -Donovan-LuminaryNiwaStanley,I had this issue in the past too. Until Netgear and Netduma release a new firmware for the XR500, to solve my problem temporary I had connected a second router in AP mode to my XR500. Then, the Philips Hue Bridge v2.0 will be connected on the second router and you should be able to run your lights without any problems.
- Netduma-FraserNetDuma PartnerDo you have another router you could try to have it handle PPPoE and then connect the XR500 to it and try it then? Are you able to try and connect/pair with it from another wired device?
Could you also try setting a guest wifi network on the router and try it using that please?- -Donovan-Luminary
You can not configure the Phillips Hue Bridge v2.0 in wifi.
The Phillips Hue Bridge v2.0 can only be connected using an Ethernet cable from the unit to the Ethernet port of your router.
