× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Questions about the router
Gimli
Tutor
I wonder if this router needs a notebook base to cool? Does it get very hot?
Can he stay connected 24 hours a day 7 days a week direct?
Message 1 of 8
Accepted Solutions
JasonN
NETGEAR Employee Retired
Re: Questions about the router
Hi Gimli,
If you are referring to the XR500, then it does not need any cooling. I have the XR500 at my desk and it's been on 24/7 as well and its runs about room temperature.
Just make sure that you don't place the device in an enclosed area. :]
- Jason N
Message 5 of 8
All Replies
BIG_DOG
Luminary
Hi.
The router does not get very warm. Mine has been on 24/7 since I purchased it on March 6th. Just make sure it in not in an enclosed space and has ventilation.
Message 2 of 8
Netduma-Fraser
NetDuma Partner
Hi Gimli, I would just reiterate exactly what BIG_DOG has said above!
Message 3 of 8
Danny80916
Luminary
Mine stays pretty cool, I would say its room temperature maybe a degree higher . My modem on the other hand I could probably crack a egg on it and fry one no problems.
Message 4 of 8
JasonN
Hi Gimli,
- Jason N
Message 5 of 8
Gimli
Tutor
Is it necessary to put something underneath it, to be suspended and to have a better circulation of air?
Thank you
Message 6 of 8
Danny80916
Luminary
Mine is ontop of my blu ray player with nothing around it. My router is perfectly fine.
Message 7 of 8
Netduma-Fraser
NetDuma Partner
As long as it's not on a surface that would contribute to overheating such as carpet it should be fine.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4165 views
  • 4 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
