ElVapo's avatar
ElVapo
R7500 and XR500 Comcast setup??
With a R7500 modem/router and a XR500 router what is the best way to connect them so they’re on the same subnet?  Would the XR500 be an AP?  Is it possible to create a bridge?  Do the routers need a hardline or wireless connection?
  • > With a R7500 modem/router and a XR500 router what is the best way to
    > connect them so they're on the same subnet?
       An R7500 (or R<anything>, for that matter) is a router, not a
    modem+router.  "Comcast" suggests that there's a cable modem (or
    modem+router) of some kind involved somewhere.  A complete, accurate,
    detailed equipment inventory might be a good first step.  Is your
    "R7500" a plain/"v1" or a "v2" hardware version?  Look at the product
    label.
       One way would be to configure all but one of your routers as wireless
    access points.  For example, visit http://netgear.com/support , put in
    your actual "R7500"(-like) model number, and look for Documentation.
    Get the User Manual.  Look for something like "Use the Router as a
    Wireless Access Point".
    > [...] Would the XR500 be an AP?
       It could be.  Or the R7500 could be.  If you also have some other
    router, then both the XR500 and R7500 could be.
    > [...] Is it possible to create a bridge?
       I don't know what that means in this context.  What, exactly, would
    "a bridge" be doing for you?
    > [...] Do the routers need a hardline or wireless connection?
       As the picture in the manual shows, a wireless access point normally
    uses a cable connection to the main router.  But other modes of
    operation exist, too.  For example, look for "Use the Router in Bridge
    Mode" in the R7500 manual.
    • ElVapo's avatar
      ElVapo
      Thanks for responding. My modem/router is Nighthawk X4 Cable Modem Router AC3200 and I have a XR500 Gaming Router.
      I have Comcast cable for the Internet.
      I saw the article on bridging the R7500 with another R7500 but not how to create a wireless bridge between the R7500 and the XR500.  I was hoping for some insight into the specific differences because the UI is different in the XR500.
      Running a cable between the routers is an option but I’d like to run wirelessly in bridge mode on the XR500 if it’s possible.
      I'm looking for the simplest solution that provides me wired acces points with Wi-Fi at both routers.  I’d like both routers to be on the same subnet.
      Any suggestions about how to connect and configure the devices is appreciated.
      • michaelkenward's avatar
        michaelkenward
        Your message says Nighthawk X4 Cable Modem Router AC3200, which is a wifi speed indicator rather then a Netgear model number. Your footer says R7500.
        My guess is that you really mean C7800. That seems to be the only cable modem that does AC3200.
        Using something like the very expensive XR500 (really an R7800 on steroids) in access point mode is likely to throw away much of its function:
        Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
        So using the C7800 in bridge (modem only) mode may be more sensible.
        There is a manual for the C7800 somewhere at the end of this link:
        >>>> C7800 | Product | Support | NETGEAR <<<<
        Unlike many devices, the manual for the C7800 does not have a section on how to use it in modem-only mode. Nor even any mention of bridge mode. It may be simply a case of disabling the DHCP server on the modem/router.
        Unless someone else steps in, you may have to do some research.
