Guffy
Dec 14, 2020Aspirant
Rebooting XR500 will not connect to internet
Purchased router in May 2020. XR500 & Arris SB6190... When rebooting network (whether for performance based or firmware update or power outage) I must unplug hardwired Ethernet connections prior to the router rebooting otherwise I will have no internet. This as well as inconsistent smart home devices not connecting to network has been an ongoing struggle since July 2020. Firmware is up to date. Have performed reset and setup router again (twice). Gave up on Netduma (probably my fault) but no matter what settings I mess with regarding this OS it just increases failure in something else. At this point I leave all the gaming stuff and allocation settings disabled or what they were set on out of the box.
Any suggestions or links anyone knows of to help would be appreciated. I tried calling, not realizing that 1 yr manufacturers warranties are helpful unless you pay a premium. I have yet found a solution online (netgear forums or web links) that have helped.
- Netduma-LiamNetDuma Partner
Hey,
Could you explain this a little further? Do you mean that you will not have an internet connection over these devices when the router comes back up again?
If there were any other issues you experienced that caused you to give up on DumaOS, just let us know and we'd be happy to help.
- GuffyAspirantSo yes no internet upon a reboot of the router. To ensure that the router will reboot with internet I must disconnect the hardwired devices I have connected, then allow the router to reboot. I have tried removing 1 Ethernet connection at a time and rebooting to see if it was a specific device, this does not matter. I have my PC and an Linksys gigabit switch hardwired to the router. Removing one or the other does not change the outcome. Remove both and it will reboot with internet. (Note* I tried an Ethernet cable not connected to any device, same result not internet upon reboot). I also have Wemo and Philips hue devices that have intermittent issues, mainly app being able to connect to the devices.
DumaOS issue, I finally found settings that worked well with my area for server connections while gaming. Then I started having problems with my Ring devices not staying connected or my app not being able to connect and see a camera. Disable Duma no consistent problems with Ring. Also adjusting priority or bandwidth induces lag on my gaming pc.
The router is setup for Auto Connect between 2.4/5. I have previously tried separating the bands but saw no change in device performance.- Netduma-FraserNetDuma PartnerWhen you're disconnecting the devices are you also disconnecting the ethernet cable connecting the router to the modem? If you reboot the modem just after you reboot the router (devices connected) does the internet come back up? Just to clarify, you're referring to disabling QoS completely? If so re-enable it and instead disable DumaOS Classified Games and any manual rules on Traffic Prioritization and see if it still works. How were you prioritizing the PC previously? For those devices I would advise disabling Smart Connect - you can try adjusting the co-existence option and I would suggest using a WiFi analyzer to find the least congested channel and change to that.
