KHdV1966's avatar
Nov 14, 2020
Replacement antennas for XR500
I lost my antennas while moving to my new house. Is it possible to replace them and where can i sell them? I have been lookin around the internet en at the netgear support site but can not find anything.
  • plemans's avatar
    The xr500 uses RP-SMA connections. any 2.4g/5gh antenna should work to replace them. there's a bunch on amazon.
    Netgear doesn't sell replacement antennas.
    • plemans's avatar
      shouldn't have said "any". You just need to make sure the plug connector is long enough so you can angle the antenna's. Some come with shorter connections.
      • KHdV1966's avatar
        KHdV1966
        Tutor
        Yes thats the problem. I need at leas 30mm before the antenna bend upwards
