wolftiger21
Sep 26, 2020Tutor
Rural Gaming Questions
Hello,
Moving to a new home with only cellular for internet. Will any of the netgear gaming router work in this situation? Or Suggestions for a setup? If not direct to the netgear, I worry about the NAT situation with another router in front of it. Thanks for any help.
- You would need to use it with a router that accepted a SIM card for internet. You will be able to use them together and eliminate a double NAT while getting the best connection possible.
- Netduma-FraserNetDuma PartnerYou would need to use it with a router that accepted a SIM card for internet. You will be able to use them together and eliminate a double NAT while getting the best connection possible.
Thank you!
- Netduma-FraserNetDuma PartnerYou're welcome! If you decide to get a Pro Gaming router do post back here and we can help you resolve the NAT.
