- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgrade from xr500 to xr1000 PS5 Console issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all. I’ve been using my xr500 for a while with no issues (finally), but the resets have been becoming more necessary recently to keep it connected to the internet so I upgraded to the xr1000.
This has been fraught with problems. I used the exact same channels as before but just about every hot connects at a slower bandwidth. The really strange ones are the iPhones which would always connect to 5ghz with smart connect on before but now just stay on 2ghz even though they’re physically close to the router. My LG tvs internal app to YouTube struggled a bit as well.
However the possible deal breaker to return this thing is my ps5. It consistently gave me a “possible security error” when trying to connect. I changed the security to a different setting and it worked for a brief time but restarting the ps5 always drops it off the network. If I put the ps5 in automatic band mode (instead of 5ghz) it connects fine but this was never ever an issue with the xr500.
Any ideas what’s going on here? Since the xr500 was not broken but only slightly showing some signs of age I will have no problem going back to it as it current has far superior performance for me over the xr1000.
Thanks for any help…
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgrade from xr500 to xr1000 issues
If your noticing similar problems across two different model routers, possible you have a mis configuration or environment problem.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How do you have Wireless settings under Basic and Advanced configured?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
I'm using channel 1 and 40 with AX, OFDMA, Beamforming and MIMO all enabled. 40Mhz coexistence only on 2.4Ghz on my 1000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had all my settings the same as you below but I also tried disabled ax features. I left the xr1000 in auto mode (and lowered the 5ghz bandwidth to enable that) but I routinely use a network analyzers and funnily enough it picked the exact same channels I had for the xr500, namely 36 for 5 ghz which is the problem channel.
I just reinstalled the xr500 with the same channel and all my previously mentioned problems went away. iPhones connect to 5ghz with over 500 Mbps down (I get around 780 at the modem) and the ps5 connects immediately and has around 400 Mbps down from its internal test.
Also- I’m using the same netgear cm600 modem I’ve always had with my Comcast cable IP in the states.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is what I get on my iphone with the XR1000:
Using channels 1 and 40.
Router was factory reset and setup from scratch after I applied v.64 FW.
Mines connected to a CAX80 on a 1Gb/50Mbps ISP line.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any other ideas as to why that may be?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you changed the security it uses?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please go to Settings -> Setup -> LAN Setup and try reserving an IP address for the PS5. Ideally, give it an address that's outside of the DHCP range, you can see what this is a bit further up in the page.
After that, see if it can maintain a connection after a reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the PS console connect ok using a ethernet connection to the XR1000?
Possible that the PS console wifi device could be faulty. I've seen some consoles not have good wifi devices or connect or operate well over there wifi adapters.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This applies to the static IP suggestion as well- the xr500 didn’t need this but I can try it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
And you set XR1000 wifi settings to same as XR500?
Disable AX mode on the 1000 router as well?
@niewiado wrote:
I haven’t tried that, but besides not really being a long term option, the xr500 connects to the ps5 flawlessly with an almost constant 100% signal strength (it’s directly above the console).
