mpsalkin's avatar
mpsalkin
Upgraded XR500 to V2.3.2.130 and shortly after all LAN ports not connecting to my devices
Hello,
I recently purchased the XR500 a few weeks ago, upgraded FW to .114 and everything was working well. Then FW V2.3.2.130 was released so I upgraded and again everything seemed to be operating well. I came home from work today and none of my devices connected to the LAN ports have internet, all showing offline in the device manager. All devices connected to WiFi are running just fine.
I have not really configured any advanced settings. Just Setup QoS with my xbox and connected some devices to my VPN service via Hybrid VPN (however, none of the devices on the LAN are connected to the VPN). I tried rebooting the router, disabling QoS and disabling the VPN to no avail.
Any ideas on why my LAN ports randomly stopped working when they were all working last night?
Thank you in advance for any input.
Matt
  • Hey Matt, thanks for detail!
    Are you able to get to the DumaOS interface when using a device connected via ethernet?
    What lights are illuminated on the XR500 and what colour are they?
    Did you factory reset the XR500 after installing the latest firmware?
    • mpsalkin's avatar
      mpsalkin
      Hi Liam,
      Thank you for your quick response.
      The lights were lit white on the modem for 2/4 connected devices (the other two may have been offline from inactivity).
      I did not attempt to connect to DumaOS interface via ethernet cable, nor did I perform a factory reset as I didn't want to loose my configurations for device names and QoS. Is a factory reset required after upgrading firmware?
      I went through my xbox troubleshooting and it said the router may not be assigning an IP via DCHP and to try to give it a static IP. I gave that a shot and after clicking apply 3 times in the LAN setup menu it actually connected. I then gave the other 3 LAN devices a static IP as well and sure enough they connected. I then removed the 3 LAN devices from static to automatic and they were still able to connect. Not sure why that seemed to kick it into gear...
      Matt
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        We do reccommend a factory reset after upgrading firmware just because it's good for clearing out anything that could've been left over from the previous firmware. It's not always essential though.
        It sounds as though the DHCP server is having trouble on the XR, though it's odd it only seems to be affecting wired devices.
        It wouldn't be a bad idea to reserve IPs for these devices anyway, while we investigate DHCP issues with the XR routers. If you still have problems after that, please do let us know also.
  • FURRYe38's avatar
    mpsalkin wrote:
    Hello,
    Matt
