- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
VLANs on Nighthawk Routers
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible to setup VLANs within the OS of the XR500? Ideally create two networks that are truly separate from each other where devices on each cannot see or access each other. I see there is a VLAN/bridge but does that mean the only way you can have a VLAN also enables a bridge? If that is the case I assume it will bypass the NAT, which someone may not want. Or mabe it is possible to have a VLAN without a bridge, therefore utilizing the NAT. If anyone has done this please let me know. Also any documentation is helpful. Cheers!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: VLANs on Nighthawk Routers
There is VLAN on my XR450:
Wired Ports | Wireless | ||
(if required; range: 1~4094) |
Found under Settings/Advanced Settings/VLAN_Bridge Settings |
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router MK83+ (Router Mode) | and RBK853 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, R9000, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
A reason to have a VLAN or even separate network is for IoT devices. Has anyone accomplished this config ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Considering purchasing the XR500. For anyone that has setup a guest network, are you able to tell me what internal IP it provides? Can this be changed and is it truly isolated from your main?
- Mark as New
- Bookmark
- Subscribe
- Permalink
