× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Weak Signal Zero Distance
Whiskey8
Guide
Model: Nighthawk (XR1000) AX5400 - Couldn't find that model in the dropdown for model number.
PurchaseDate: 8 March 2022
FirmwareVersion: 1.0.0.58
Current GUI Language Version: V1.0.0.46_2.1.46.1
Problem:
Weak WiFi signal. Signal strength doesn't go up even placing phone directly next to router or antenea.
2.4GHz device named Elisa iPhone was in same room with clear line of sight. Approximately  4ft away from router.
5GHz device named Shane iPhone was 1inch from router for testing. Even directly next to the router signal strength was minus 1.
EDIT: Not sure why the image isn't showing up. I attached the image as well.
Router Placement:
Router is on wood TV stand. There are no shelves above or to the sides the router (open air). Electrical devies near router are TV and Xbox Series X. Previous router, TP-Link Archer 5400 provided full signal strength in the same location.
Steps taken:
  • Initial setup using guided setup via Nighthawk App.
  • Checked for firmware update via App - no update found.
  • Checked for firmware update via DumaOS - no update found.
  • Enabled IPv6 through DumaOS.
  • Ensured QOS was off.
Message 1 of 3
Netduma-Fraser
NetDuma Partner
Re: Weak Signal Zero Distance
Try these suggestions:
Disable Smart Connect, give 2.4/5GHz different names and apply - you'll want to connect to 5GHz specifically for speeds
Use a WiFi analyzer to find the least congested channel and change to that
Set the antennae to this position _ | | _
Message 2 of 3
Whiskey8
Guide
Will try all above and follow up. Thank you for the tips.
Message 3 of 3
Discussion stats
  • 2 replies
  • 897 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
