Rathen88
Apr 16, 2023Aspirant
XR1000 Turn Off Wireless Broadcase
So I've turned off the wireless by pressing the wireless on/off option on the router itself. However, when logged into the router settings itself both wireless radios are still broadcasting. And I can't find a way to turn off wireless at the OS itself.
Do I rely on the on/off switch on the router itself or is there a dumas/setting that I'm missing. Thanks.
1 Reply
After you press the wifi ON OFF button for 5 seconds then release, Do you see the routers SSID still on any wifi mobile device or no? If NO then the radios are OFF.
