×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
XR1000 router firmware 1.0.0.68
lincssausage
Guide
I stumbled upon this link yesterday which is supposedly to 1.0.0.68 firmware for the XR1000:
https://drivers.softpedia.com/get/Router-Switch-Access-Point/NETGEAR/NETGEAR-XR1000-Router-Firmware-...
I downloaded the zip and it has a release notes file XR1000-V1.0.0.68_1.0.54_Release_Notes.html
Is this something that was leaked? Is it a hack attempt? The latest version I am aware of is 1.0.0.64. Can someone shed some light on this?
Message 1 of 8
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: XR1000 router firmware 1.0.0.68
The firmware was accidentally uploaded before it was ready and was then taken down. I would not recommend downloading firmware from anywhere but the official source and especially in this case downloading a firmware that was not meant to be upgraded to and therefore could have lots of issues if you were to upgrade.
Message 3 of 8
All Replies
Guru
Probably leaked or some hack. I see it's been removed.
Only get your FW files from NGs main download page:
https://www.netgear.com/support/
Or from here in the forums. Avoid any 3rd party sites.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 8
Netduma-Fraser
NetDuma Partner
Message 3 of 8
lincssausage
Guide
Re: XR1000 router firmware 1.0.0.64
Thanks for the replies. I figured it was a leak or something similar. I have not installed it. The official firmware seems to be a bit unstable at times so I did not want to rock the boat with unreleased firmware.
I've had 1.0.0.64_1.0.49 installed since it was released and it worked well for a few months. The past month I had to reboot my router every day or two and my throughput was slowing. My family was all complaining of bad internet speeds. It checked with a computer connected directly to the cable modem and I was still getting about 1Gb down which is normal. The DumaOS UI would stop responding too until rebooted. I had to do a factory reset on the router for speeds to return to normal. I also did a factory reset when installing 1.0.0.64. This is the third or fourth factory reset I have done since I bought the router because it keeps doing this after a few months. This is why I was looking to see if there was new firmware.
It's working fine right now but chances are it will start running slow again. I switched from a TP-Link Archer AX50 which loved to overheat. It also liked to slow down if I did not reboot every day. It would crash when uploading large files to the attached USB drive. I can't get away from router issues.
I might build my own router box next time.
Message 4 of 8
Netduma-Fraser
NetDuma Partner
If it happens again downgrade the firmware and see if you have more stability on that one in the meantime.
Message 5 of 8
Guru
FYI, new FW is available:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-XR1000-Firmware-Version-1-0-0-68-R...
@lincssausage
Message 6 of 8
MetFox123
Guide
Still no hybridVPN?? is this a joke?
Message 7 of 8
Netduma-Fraser
NetDuma Partner
Netgear had to release a version as soon as possible to fix a security vulnerability, more updates will be coming
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1763 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
