- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR1000 won’t load Geo Filter or Ping Heatmap
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR1000 won’t load Geo Filter or Ping Heatmap
What firmware version are you on currently?
After updating the firmware, have you factory reset the XR? If not I'd suggest doing so as the issue could be related to some old low-level code from an old firmware and may have been carried over to the newer firmware when you upgraded.
Are you getting any error messages when trying to load these two features?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have also some trouble getting in the ping heatmap section. The geo filter works, but ping heatmap keeps showing this.
And also can you update the FIFA22 servers on xbox? Recently I keep showing I am getting peer servers when my in game ping is 22ms but my opponent was 8ms. The geo filter showed me my own location which is really weird, can you please look into this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have the list of FIFA22 servers right now in North America? Xbox series X nextgen specifically
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you reboot the XR, are you then able to load Ping Heatmap?
When did you first start noticing this problem? Did it occur after any configuration changes or firmware updates?
I don't have a list of servers to hand, the best thing to do would be to work out this problem so you can use Ping Heatmap for this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m having the same problem my geo filtering and ping heat map aren’t loading at all. It keeps on telling me raps not loaded
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
rebooted router, geo filter wont work on PC macbook anymore, tried a couple more reboots still same message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could you please clear your browser's cache/try accessing the interface from an incognito/private window? See if Geo-filter can then load properly after that.
User | Count |
7 | |
4 | |
3 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
