- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
XR300 Poor Speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I've read quite a few "slow speed" threads on here, and tried some of the various tips that were suggested in them but none seem to make a difference. In the other threads I saw a lot of people ask the same questions for info, hopefully I've included everything you need to know below. There is also a link to a shared google photos album where I have put some screenshots. Also not sure if it's relevant, but I'm in the UK.
First off equipment, then we'll get into it.
All cables are cat6 and tested as working full speed (via ISP router, & via switch)
ISP modem -
Model: MT992
Router
Nighthawk XR300
Firmware: XR300 1.0.3.38_10.3.30
Switch
TP-Link TL-SG1008D 8-Port Desktop Gigabit Ethernet Switch
Desktop PC
Windows 10
Onboard network 4 - Killer E2400 Gitgabit
Phone
Google Pixel 3 - Android 10 QQ1A.200205.002
Previous setup was-
BT openreach modem>EE Smart Hub>TP Link switch>PC and was comfortably getting speeds over 100 constantly.
BT openreach modem>EE Smart Hub>Phone (via 5ghz)
Current setup is-
BT openreach modem>XR300>TP link switch>PC and haven't gotten over 24 yet.
BT openreach modem>XR300>Phone (via 5ghz)
I have tried turning off Qos, I have tried it with always on and also never. I have put my expected speeds in (as you can see with the images) but nothing seems to make a difference.
With the ISP router I was getting speeds greater than 100 on both my phone and my PC, and now with the XR300 I am getting less than 25. I read in one of the threads that it might take a few days to "settle with your ISP" so I have waited a few days and no change, so here I am.
I have added comments to the speed screenshots to say what they are from - https://photos.app.goo.gl/7WpVeGVcjF6sBYW28
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: XR300 Poor Speeds
The more complexity you add, the harder it is to help diagnose.
Start back at basic to figure out where the bottleneck is. First get the hardwired speeds up to where they need to be. I'd also recommend starting with the XR300 in default configuration so an old setting isn't causing the issue.
modem------PC: speed?
modem-----xr300-----pc: speed?
modem---xr300---switch--pc: speed?
it wouldn't be the first time a cable, old setting, or even base modem was causing the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will also try a factory reset and leave settings as default. Although that's what they were to start with and I only played with settings to get my speeds back up
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd also try re-installing the firmware. A factory reset only removes the settings, it doesn't re-install firmware. If something wasn't installed correctly or was corrupt, a reset won't fix that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also how do I find out what the Mac address for my old router is. Will this be a case of plugging the ISP router back in and login to it?
Many thanks for all replies, only 4 hours of work left then j can give some of these things a go
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK so here goes.
1. Factory reset XR300 - no change <25 on PC (wired)
2. Rolled back firmware on XR300 - no change <25 on PC (wired)
3. Disabled Qos again (the box underneath where you specify your expected speeds, so everything disabled) - no change <25 on PC (wired)
4. Changed the MAC address to that of the ISP router - helped, a lot actually but still not at the speeds I was getting with the ISP router 60-80mbps
I then tried steps 1-3 again, but each time putting in the MAC address of ISP router, and each time was the same 60-80.
When I check internet speed in the nighthawk app on my phone it is continually saying 110-130 (which is what my ISP said I would expect to get) - am I right in thinking the nighthawk app is testing the speed from modem>router, and not what my device (phone in this case) is getting? If so then this solidifies my thoughts that my ISP modem is providing the correct speeds but then the XR300 is bottlenecking it for some reason.
At least with the MAC address change putting it up to 80 makes the internet usable again and I can play a few not-too-competetive games but still I would like to get back to my 130 that I was getting with my ISP router. I may just send this back and stick with ISP router. I wasn't having any issues with my PC wired speeds, I only got the nighthawk to make the wifi in the house better, but I could just get an AP/repeater instead.
Haven't tried the earlier suggestions of modem>PC and modem>XR300>PC (without switch) because even if they make a difference, the way I have my network setup that wouldn't work for me. And as previously said, with my current setup straight switchin the XR300 for my ISP router puts me back at full speed.
Thanks for all advice so far, and thanks in advance for any more things to try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Fraser, I'll be honest I haven't done any speed tests on my phone (wifi) as I've only really been concerned about my PC, all other devices can have 10mbps for all I care LUL but I will check if there is any difference between 2.4 & 5ghz.
I have only used port 1 on the XR300 but will try the others to rule that out and report back.
As for settling, lets hope that's what it is as all the reviews said this was a good buy and I was excited for new tech. I'll give it another few days (with the now correct MAC address) and see what happens if using ports 2-4 doesn't change anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it was just a settling issue then hopefully I can turn QoS back on as seems a bit pointless having this router and not being able to use that feature. Will report back if speeds stay after turning stuff back on.
Thanks again Fraser for the mac address tip, I've a feeling that rushed along the settling
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK so I've turned QoS back on, and speeds are still full and as expected. So I think it was a case of setting the MAC address to that of my ISP router, and waiting for it to settle/sync.
Thanks everyone for their suggestions & help. Very much appreciated 😄
