Billy1981
Feb 04, 2018Aspirant
XR500 Compatible with Xfinity Comcast
Will this work with Xfinity (comcast)
I really wanna pick this up
Try Motorolas MB74xx series or Arris 6183 or 8200. These are Broadcom based modems.
I have the MB7420 and connected to my XR500. Wonderful operations.
Please avoid the SB6190 and any other Intel based modems.
You can check on what to avoid here:
- Netduma-FraserNetDuma PartnerHi Billy, yes it will definitely work with your connection setup!
- Billy1981AspirantWhat would be a good combination (modem), with the xr500 as im looking to by my own to avoid rental fees
- Netduma-FraserNetDuma PartnerThere is none specifically that I would recommend but I'd say to avoid those with the Puma 6 chipset as they have issues with latency (not sure if that's been resolved on all of them yet).
