AlvinLC
Apr 05, 2021Aspirant
XR500 QOS settings keep getting reset
Why doesn't the XR500 keep the QOS settings. I'm running 2.3.2.120 and it keeps resetting the bandwidth settings I set which includes sharing excess which I have to manually turn off daily it seems. You would think that if I go into the setting to disable something it should stay that way instead of having to login sometimes multiple times daily to change it back to the settings that I want them at.
- Netduma-LiamNetDuma Partner
Is it just the Share Excess settings that aren't sticking or are all features in QoS not maintaining changes that you make? Do you know approximately how long it takes for these settings to be reset?
- AlvinLCAspirantI know at the very least it's the share excess, but I think other settings are resetting as well. The little popup help boxes are reappearing as well, I have no idea what's going on.
I can't give you an exact time frame, but I'll keep an eye on my log today. Since the time I posted this initially and right now, I've had to reset the settings twice.
At this point I'm not sure what I should do. I've heard great things about this router, but can't seem to get any consistent usage out of it. I might go the route of others and just go with the router with best overall coverage and good speeds. Out of warranty period, but bank will still give me a full refund if I can show them that the problems were from the get go.- Netduma-FraserNetDuma PartnerAre you trying to set both applications and devices for Bandwidth Allocation? Also are you thinking it's resetting because the Bandwidth Allocation default view may be different to what you have set? E.g. if you have adjusted devices but it defaults to application view you may think it has reset when it hasn't
