Orbi WiFi 7 RBE973
Reply
XR500 QoS device not found error after factory reset
Agentwhite
Star
I randomly started having problems with my XR500 where it would just keep rebooting itself. I tried a factory reset which so far has solved the rebooting issue, however now when I got to the QoS tab in DumaOS I receive an error saying "Device not found". I have re-connected all the device which I had set up QoS for but still see the error. The congestion control and Bandwidth allocation widgets load fine, but the bottom left widget just spins. Any idea how I can fix this?
Message 1 of 8
Accepted Solutions
Agentwhite
Star
Re: XR500 QoS device not found error after factory reset
For anyone else finding this, I was able to solve the problem by downloading the DumaOS app on iOS. From the app I could load everything fine, I then deleted the devices defined in the traffic prioritization widget. Then went back to PC browser, everything loaded fine and I could re-add my devices.
Message 2 of 8
All Replies
Agentwhite
Star
Message 2 of 8
Netduma-Fraser
NetDuma Partner
Thanks for the solution we haven't heard that one before and is certainly a more painless way of resolving it so we'll keep that in mind!
Message 3 of 8
Kevin1199
Guide
How would you even download any app to iphone if the XR500 does not have a Duma app.
Message 4 of 8
Agentwhite
Star
Message 5 of 8
Netduma-Fraser
NetDuma Partner
As above, that is the official mobile app from us!
Message 6 of 8
boricuajr84
how do you log into this app for Android? Same log in from Routerlogin.net?
Message 7 of 8
Netduma-Fraser
NetDuma Partner
So search DumaOS on the Google Play Store and then login using the same credentials you would use to access the interface on a PC
Message 8 of 8
Discussion stats
  • 7 replies
  • 2128 views
  • 4 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
