Rab1967's avatar
Rab1967
Tutor
May 06, 2021
XR500 and Xbox Console - How do I get Geo-filter to connect me to USA Host when I am in Europe?
I bought the XR500 becasue of the Geo-filter capabilities, but I thought it would allow me to selectively adjust where I wish to connect to gaming servers, even if in another country.
However, I always seem to get connected to european servers no matter how I setup the filter. I am in the UK, but I want to connect to USA servers.
I use XBox Console, playing Call of Duty and I set radius over East US with 500 mile range, Strict Mode is On, Ping assist is set high to allow for the distance, but every server or peer I connect to seems to be showing on the map as in Europe. I've tried with Fast Search on and off. I do get connected to games, but not where I have set the filter radius.
This seems to be against what the product was advertised to do.
  • You will need to set Ping Assist to 0, that is how you force servers in another country, otherwise it may get you games closer to home.
      • Rab1967's avatar
        Rab1967
        Tutor
        Ping Assist at 0
        It seems that in my case setting Ping Assist to zero, does not work. My connection are still all initiating in Europe.
