× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR500 as wireless ethernet bridge
engneerngDynamo
I want to setup my XR500 as a wireless ethernet bridge.
Why?  Becuase I have an XR500 and 4 devices that do not have WiFi adapters in a room that I can't run a wire.
I know I could use a cheaper router to do this, but I already have an XR500.
I don't need to use the wi-fi on my XR500, except to brigde to another router.
(If I could run a wire, I would use a 5 port Gb switch)
Netgear has instructions for how to set up a router in bridge mode:
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
But I think these instructions are not for the XR500.
Any help is appreciated.
Model: XR500| Nighthawk Pro Gaming Router
Message 1 of 8
Netduma-Fraser
NetDuma Partner
Re: XR500 as wireless ethernet bridge
As far as I know this isn't possible with the XR500. We didn't create the Settings though so maybe worth giving Netgear a call to double check.
Message 2 of 8
JasonN
NETGEAR Employee Retired
Hi engineeringDynamo,
That KB instructions is not for the XR500. You can see on the right of the page that it lists all the devices that those instructions go to.
- Jason N
Message 3 of 8
engneerngDynamo
Yes, thank you.  I know.
I should have stated that I am aware those instructions are for other routers more clearly in my original post.
Message 4 of 8
engneerngDynamo
In my defense, the KB article does have "Nighthawk" in the URL:
and this is in there: "Installing your Nighthawk router as a bridge offers the following benefits:"
The XR500 is a nighthawk router.
So I thought maybe it might apply.
Message 5 of 8
engneerngDynamo
Netgear support answer:
There is no current option to set the XR500 to wireless ethernet bridge. For now, it only applies to several models. However, you can submit an ideas using the link below.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
l just bought:
NETGEAR Nighthawk AC1900 Desktop WiFi Range Extender (EX7000-100NAS)
I think this will be an easy to setup wireless ethernet bridge.
Message 6 of 8
JasonN
Thank you for updating the thread. I'm glad you have found a workaround.
Please let us know if you have any other questions. :]
- Jason N
Message 7 of 8
Danny80916
Luminary
I have that same extender its , amazing piece of hardware so many options for it .
Message 8 of 8
Discussion stats
  • 7 replies
  • 7716 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
