Jaydos101's avatar
Feb 17, 2023
XR500 internet keeps cutting out daily
I own the Xr500 my internet keeps disconnecting daily for 4 months plus and idk what to do it cuts out on all devices wireless or wired, turning it off then on will fix it for a short while i've tried hard reseting multiple times nothing has worked
  • In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
    • Jaydos101's avatar
      Jaydos101
      Tutor
      Do you mean in LAN setup ?, It says address reservation add.edit,delete are you talking about that section ? thank you for your response
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Yes that's right, so change the DHCP range first, then set the address reservations for devices.
