DayleMaskey's avatar
DayleMaskey
XR700 Cloud Flush not working
Hey guys!
I have an XR700 and cannot get the flush cloud option to work. I get the error "The operation is taking longer than expected. Please briefly wait before using this R-App." I've cleared the devices that were attached, Factory reset the router and even reloaded the current firmware. I'm completely stuck.
Thank you in advance!
  • You can ignore that, wait 1 minute and refresh the page, it will have applied successfully - there is no confirmation message
    • DayleMaskey's avatar
      DayleMaskey
      Thank you for getting back to me Fraser. If this is the case then I'm stuck with another issue. I was trying to use the flush cloud option because I am not able to find any servers all of a sudden. I am playing Halo 5 on Xbox Series X. Until a few days ago the GeoFilter was working perfectly then one afternoon I couldn't get any servers to show up on the map and if I had it on strict I cannot find any games (it will come up saying connecting to dedicated server then boot me} but still nothing coming up on the map. Do you have any suggestions?
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        If you fuly zoom out on the Geo-filter map when searching for a game, do you see any 'blocked' icons appearing on the map? I believe there may be an authentication server in Australia that might need to be whitelisted, though your mileage may vary.
        If you search for a game without Geo-filter filtering, do you now get in to a game no problem?
