× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
XR700 igmp snooping with gs810emx
Gardone8876
Guide
I have a XR700 connected to a GS810EMX switch. Does "IGMP Snooping Static Router Port" need to be set on the GS810EMX? Does the XR700 send out igmp queries periodicly? I have unchecked "Disable igmp proxying" on the XR700. Does the XR700 support igmp snooping?
Model: XR700| Nighthawk Pro Gaming Router
Message 1 of 4
Accepted Solutions
Guru
Re: XR700 igmp snooping with gs810emx
Does the user manual have any information regarding this feature? I would presume if you don't have a need for IGMP protocols, then it could be disabled.
I would ask for support on the GS810 switch to see if that should be configured only or if both need to be configured.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
All Replies
Guru
Message 2 of 4
Gardone8876
Guide
Thanks I'll make a new thread to ask for help with the gs810emx
Message 3 of 4
Guru
Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1900 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
