- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Xr500. Is it possible to get full speed on ps4
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess what I’m asking is with those router features is there any possible way for the ps4 to reach the same speeds as my other devices.
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Xr500. Is it possible to get full speed on ps4
First of all, Speedtests through a console are usually not that reliable, so I wouldn't put too much stock by the result you are seeing.
Secondly, what mode is Antu-Bufferbloat in? My guess is you have it on High Priority Traffic Detected mode. So when you boot up your PS4, it activates Anti-Bufferbloat, which then reduces your speeds.
If you want to maximise these but get the best QoS when gaming, see this guide: http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. I have everything you stated done. Anti buffer bloat to 70 on download and upload and set to high priority traffic. The only thing i didnt do was change my flower, which is default set to split the bandwidth everywhere. Everything seems to work fine it was just the issue with the slow lan speed test on my ps4.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah it is just slow speed test. If i hardwire to the modem, or use a different router the speed test on the ps4 is closer to my 100/10. It is usually somewhere around 85/8. With this router and the option on we spoke about the best i can get on a speed test is around 35/3. Ive tried about 20 speed tests on there. When im on the ps4, all my other devices get around 70 down and 7 up which im assuming is because the anit buffer bloat is set to 70% on a 100/10 connection. Which is fine. I just dont understand why i cant see those speeds on the ps4 through this router. As i said the other router is fine (asus ac86u) and directly to the modem is fine
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
