Orbi WiFi 7 RBE973
Reply
Xr500 configure channels
Linchpin78x
Tutor
Been going through a trouble shooting situation with turtle Beach for my headset . Their current request to try is to configure the router to I guess avoid certain channels I'm guessing under the 5g band. Or to disable the 5g band if it's not being used . I tried going through the different menus and such for the routers webpage but I don't think I'm seeing what I need or maybe it's just not there. Any help or point in the right direction would be greatly appreciated.thank you.
Message 1 of 5
Accepted Solutions
Netduma-Fraser
NetDuma Partner
Re: Xr500 configure channels
There is a guide here on how to change a channel but it's basically click the dropdown list and select another: https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
There is only the one channel for 2.4GHz and then one for 5GHz. If you're using Smart Connect you'd need to disable this first so 2.4/5GHz can be separated and then you can change the channels. You can just try experimenting with the channels or there is a free WiFi Analyzer (literally called WiFi Analyzer) on the Microsoft Windows Store that you can download and use to check what channel might be best for you.
Message 4 of 5
All Replies
Netduma-Fraser
NetDuma Partner
I think it's more like 2.4GHz that would be causing interference. It would be on the WiFi Setup page
Message 2 of 5
Linchpin78x
Tutor
Thanks for the reply.. are there any links or sites that can explain what needs to be done ? because unless im not looking at it correctly it looks like i can only adjust a singular channel .. currently its set to auto..
from the support this is what they are suggesting to try ...
"Configure Your Wireless Environment to Reduce Interference:
If you are not using any 5 GHz devices, shut off the 5 GHz band on your router. The router should have come with documentation explaining how to do this. If not, the router manufacturer support team can assist you with this.
If you know you are using the 5 GHz band, try configuring the router so it stays above channels 36, 40, 44, and 48. These are the channels most frequently used by our wireless headsets, so it's best if the router does not use these channels."
i've never really ventured into router settings this extensive or that seem extensive. thanks again for your help.
Message 3 of 5
Netduma-Fraser
NetDuma Partner
Message 4 of 5
Linchpin78x
Tutor
ok thank you again .. been busy with work so hadn't had much time to mess with this.
Message 5 of 5
Discussion stats
  • 4 replies
  • 1450 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
