Orbi WiFi 7 RBE973
Reply
Xr500 nighthawk not connecting to ps4
Mrcurlyyyy
My nighthawk router works on everything including my phone, laptop, even my TV but when I try to get it on my ps4 it always says it can’t connect to the internet.. I tried restarting I tried everything and nothings working. I don’t know what to do, need serious help
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 5
Guru
Re: Xr500 nighthawk not connecting to ps4
what modem/gateway is it connected to ?
What firmware is on the router?
did you go into the ps4 and forget the network and then retry?
Message 2 of 5
Mrcurlyyyy
I’m using a spectrum modem and router..
I’m not entirely sure what you mean by gateway I’m not to big on this stuff. I did try disconnecting multiple times and I get the same result. And I have it plugged in via Ethernet cord so I’m just confused and don’t know how to fix it
Message 3 of 5
Guru
the spectrum modem/router is the gateway. What model is it?
And not just disconnecting but erasing the settings for the wireless.
Message 4 of 5
Netduma-Fraser
NetDuma Partner
How have you setup the console to use the internet, are you using automatic settings or have you entered anything in manually?
Message 5 of 5
Discussion stats
  • 4 replies
  • 1837 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
