× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Xr500 router, only a amber power light is on
Adamr777
Can’t get access to my xr500 router, as the only light that comes on is a amber power light.
Iv tried all sorts of factory resetting nothing has worked so far.
Model: XR500|Nighthawk Pro Gaming Router
Message 1 of 8
Guru
Re: Xr500 router, only a amber power light is on
sounds like you might have a corrupt firmware issue.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 8
Netduma-Fraser
NetDuma Partner
As above, would recommend reinstalling the firmware with TFTP
Message 3 of 8
Adamr777
Did it step by step a few times and it said succseful, the router amber light changed to a solid white light for about five seconds and then went back to amber, the same as before
Message 4 of 8
Netduma-Liam
NetDuma Partner
Which firmware is it that you're reinstalling? What's the version number?
Message 5 of 8
Adamr777
V2.3.2.114.img
Message 6 of 8
Guru
Have you tried using an older version of the firmware?
Message 7 of 8
Netduma-Fraser
NetDuma Partner
As above, try an older firmware, would also be good to do another factory reset once you've completed the TFTP transfer and waited a few minutes.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1852 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
