gbassanini's avatar
gbassanini
Follower
Jan 10, 2020
Xr500 xbox one x disconnects
I have an Xbox one X hard wired to XR500 but it keeps getting disconnected even after setting “energy saver” mode on xbox power settings. It happened to my xbox one as well and thought it was an issue with my console but this is a newly bought console (1 month old) and the issue persists. My router firmware version is 2.3.2.56
1 Reply
  • Is this happening on all your devices? Is it definitely the internet disconnecting or is it the game being disconnected from? Does the disconnection happen when you're playing or when you next go to play the console is offline?
