× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
can i use a router with a gateway modem
Paras123
can i use a gaming router with a gatway modem from comcast ?
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 3
Guru
Re: can i use a router with a gateway modem
Yes.
With that said, if you truly want the gaming capabilities of the router, you'll need to make sure that if comcasts gateway device has an integrated router (combo device), that you disable that part of it. Or you can put the gaming router in AP mode but you loose the whole purpose of a gaming router.
More details such as model numbers would help to be more specific.
Message 2 of 3
Netduma_Alex
NetDuma Partner
You should post this in the correct forum for your model: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Message 3 of 3
Discussion stats
  • 2 replies
  • 776 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
