sdwqxvpkkdgbulh's avatar
Apr 28, 2024
netgear Night hawk router
So I just have a simple question for you guys with out physical damangeing the router is there a way to disable the physical switches to broadcast wps and turn on/off wifi. My cat keeps turning off my wifi it's geting annoying and i don't really have another spot to put the router. I was hopeing there was some setting I am missing in the os to disable the buttons if there is please let me know thanks for your time
  • Can't disable the buttons.
    Maybe tape a small sized used cardboard box over the stop of the buttons so they can't be pressed?
  • FURRYe38's avatar
