- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
nighthawk speed test
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello so whenever doing a speed test on the nighthawk xr500 while doing a network setup it says bandwidth test failed and my download Speeds look about normal but it sets my upload at 1000 mbps upload which I feel is way off (to high)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: nighthawk speed test
What FW is currently loaded?
What ISP speeds do you pay for UP and Down?
- Mark as New
- Bookmark
- Subscribe
- Permalink
To add to this - I believe Speedtest, who NETGEAR use to run this test, have had a few server problems lately which has affected this. Perhaps try running it again now and see if it's working (you will need to factory reset to reinitiate this test).
Don't worry if you would prefer not to, manually entering in your speeds is more than sufficient.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you allocate 200mbps bandwidth to a device - it will only take 200mbps when it needs it. With that in mind, what exactly do you mean by it being inconsistent? And what's your total bandwidth speed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your speed testing with a wired PC as well. Speedtest results on game consoles are known to be not as accurate and wired PC testing.
