jp_otoole12's avatar
jp_otoole12
packet burst and lag xr300 but not with my isps router help
Hi im new to gaming routers i brought the xr300  about two months ago and im finding my isps router dosnt give me packet burst or lag but when i connect the xr300 i get alot of lag packet burst while playing on ps4 ive tried the guides to no avail any help would be brilliant as i feel i just waisted my money on a product i thought would he me out thank in advance.
    • jp_otoole12's avatar
      jp_otoole12
      Thanks for speedy responce ping 25 and yes im using qos
      the problem is lag when connected to xr300 wired,But when i take the xr300 off
      and use the hub3 i dont lag at all.not just happening in one just game awell
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        That is a pretty good ping. Do my above suggestion so you eliminate the lag as much as possible.
