× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
reduce Latency on a Three: 5G BB Unlimited hub with nighthawk
seroo
i know gaming on a 5g router increase latency/ping, i was wondering if anyone knows if this can be reduced by a gaming router?
Message 1 of 4
Netduma-Fraser
NetDuma Partner
Re: reduce Latency on a Three: 5G BB Unlimited hub with nighthawk
A router cannot reduce the ping caused by the method of connection i.e. if the inherent connection is unstable you'll always still be subject to that instability regardless of the router.
Message 2 of 4
Guru
Gaming doesn't use that much bandwidth. A decent moca adapter or powerline adapter can help keep latency lower. (hardwired is always better)
Message 3 of 4
Guru
Also be sure that the higher ping and latency isn't coming from the ISP side.
Run a a test with a wired PC connected directly to the ISP modem or ONT using Pingplotter app.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 339 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
