- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
xr500 ip fragmentation ps4
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hello i have an ip fragmentation Problem with the new Duma Os.
I use the xr 500 and already test my MTU. MTU max is 1472 but i still get the IP fragmentation message when the PS4 hits the NAT test and i takes ages to end the Test. Also my internetconnection is super slow, i have 150 down and 10 up. thats okay but when i want to open a page or look a stream everything is super laggy. I have cable Internet
I need help please, i already tested so many MTU settings and nothing helps.
i saw a post where a guy gets a new firmware that solves the problem, but i can´t find it anymore
cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: xr500 ip fragmentation ps4
What FW is currently loaded?
Is the PS wired or wirelessly connected to the XR router?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Fritzbox 6490 cable with the last available Firmware from Fritz
I also have the last available firmware on the xr router. 2.3.2.32
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You ISP modem already has a router built in:
https://en.avm.de/products/fritzbox/fritzbox-6490-cable/technical-data/
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I also dmz the up from the xr. And turn all wifi off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
When I set it in the router and test the internet I have no fragmentation warnings. But for the Ps4 I have the message all the time doesn’t matter which MTU I set. Even when I put in the lowest possible.
My isp is good for 1472.
By the way Thanks for the answers
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
DMZ is not needed on the ISP modem if the modem fully in bridge mode...Are you sure the modem is in bridge mode? You can tell by looking at the IP address on the XR WAN port. It should be a public IP address, something like ##.##.###.### and not a 192 or 172 or 10 something IP address which is private.
I would set the MTU to auto as well...unless your having the XR router handle any ISP connection information like PPPoE.
What is your ISP speed UP and down that you pay for?
What is your QoS and Current Filter settings on the XR?
Review this for XR optimal settings:
http://support.netduma.com/support/solutions/articles/16000023979-optimal-settings-guide
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
37.
When I set it to auto games are mostly not playable cause of heavy lags
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Be sure DMZ is not being used while the modem is bridged.
You might do a full factory reset on the XR. Power Off the modem for 1 minute then back on. Then walk thru the setup wizard on the XR router and let it set things up again. Run some speed tests to ensure your speeds are good. The XR should auto detect speeds as it's setting up as well. After it's set up, look at the QoS settings and see if the speeds detected by the router are good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Exacly the same issue on my PS4 Pro, firmware 2.3.2.32 MTU 1492 PPPoE reset router etc the error is always present as it takes about 20 seconds to work out the Nat type on the PS4 that seems to trigger this warning. Seen it many times over the years with Netgear routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I made the walkthrough with factory reset and all the other things. Had a phone call with my isp. Everything is perfect from their side.
But I still get the warning from the Ps4 and gaming is not so much fun right now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi #Netduma- Fraser,
the Firmware that you send me really improves my internet connection.
everything is now faster, its not good but better.
The Ip Fragmentation Problem is not solved.
Still the same Message, doesn´t matter how i set the MTU in the PS4 or in the router.
Best regards,
Ingo
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
User | Count |
11 | |
6 | |
5 | |
4 | |
4 |
