ghostoflight7's avatar
Dec 24, 2018
xr500 ipv6 and speed issues
my wifi runs terribly now, i started using cat5e and its only gotten worse. my xbox wont even work being hardwired with cat5e and i dont know what i should do.. if theres any settings i need to make specific it would help me a lot.
  • FURRYe38's avatar
    What FW is currently loaded?
    What WPA security modes are you using?
  • Could you be more specific please. What speeds do you pay for? What do you get through WiFi? Your Xbox doesn't get a connection at all through a wired connection? - Have you tried using a different ethernet cable?
    • ghostoflight7's avatar
      ghostoflight7
      I pay for 400MBs and I get about 180 through WiFi, I can’t use CAT5e cables but I can use an ordinary Ethernet. I was hoping to figure out how to make the CAT5e cable work because they are way more effective.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Make sure you've input your expected speeds into Anti-Bufferbloats options. Then disable Smart Connect and use the 5GHz WiFi and you should get higher speeds. There is no different setup or anything you need to do using a different ethernet cable so it sounds like the Cat5e cables you have are faulty so would suggest get them replaced and your wired connection should work then.
