Reply
AX1800 RAX10 as a wireless bridge
EbjImmano
Can this router be used as a wireless bridge, making it connect to an existing wireless network through Wi-Fi, as a client, and provide access to that network to devices connected to its own ethernet ports? I'm trying to connect two NASes to my network from a position where no wired connection is available.
Message 1 of 4
Accepted Solutions
Guru
Re: AX1800 RAX10 as a wireless bridge
Check under Advanced tab/Advanced Settings for modes. You should see Router/AP and maybe Bridge (Wireless Bridge) if this model router supports it. Then try under Advanced tab/Advanced Settings/Wireless Settings and scroll down the page towards the bottom to see if you might see a option called "Use Other Operation Mode" maybe seen here. This would be bridge mode.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX80 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MR6150, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 2 of 4
All Replies
Guru
Message 2 of 4
davidy
Is there no way to do this in the app?  I notice there is no “advanced” option anywhere in the app
Message 3 of 4
EbjImmano
You can’t connect with the app at all io ce the device is in bridge mode, so i would think not, no.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1823 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
