× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear Nighthawk AX8 - can it be wall-mounted?
JuanHerrero
Tutor
Can it be wall-mounted?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 3
Accepted Solutions
delta092
Tutor
Re: Netgear Nighthawk AX8 - can it be wall-mounted?
Yes. I have mine mounted on the wall. All good.
Message 3 of 3
All Replies
JuanHerrero
Tutor
Come on guys! It's not a difficult question. Does anyone own one?  Are there keyhole screw holes in the base?
Message 2 of 3
delta092
Tutor
Message 3 of 3
Discussion stats
  • 2 replies
  • 1927 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
