alex_rat's avatar
alex_rat
Nighthawk AX5700 RAX75
I purchased the new RAX75 router from costco to replace my 5 month old night hawk x6s router.
On my old router I was getting close to 150 thats 147 to be an estimate what im paying for.
The new router getting 120 megs and thats not acceptable for me and I want to be able to find a fix please before I send it back in the mail to costco ?
  • michaelkenward's avatar
    michaelkenward
    The new router getting 120 megs ....
    How are you measuring those speeds?
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router. The model number could be useful.
    Apologies for all the questions. But you can help people to help you by providing the information suggested in this forum's header:
    Subject (Include model number and brief summary)
    Model (Recommended - Helps the community give the best answers)
    Body (Include additional detail including model version, firmware, OS and environment where relevant.)
    They are there for a good reason.
    • alex_rat's avatar
      alex_rat
      Via Speedtest.net and night hawk app
      modem is arris 3m3200
      after updating the channels I got 149.81 up and 10  download megs wired connect
      and WiFi 145-144 upload and download 9,81 megs
      not sure if it's running properly before I buy the extend warranty from Netgear.
