Reply
Highlighted
RAX80 - Aruba VPN fails
I am having many problems connecting to my company network through this router using Aruba VPN software. When I can get a connection, it is so slow as to be useless.
The problem reproduces on multiple devices, and those devices have  no problem connecting when this router is not involved. I don't have problems with other commercial VPNs.
I have so far tried these WAN setup recommendations, without any successful outcome
* disabling Port-Scan and DOS Protection
* enabling Respond to Ping on Internet Port
* changing NAT Filtering from Secure to Open
* disabling SIP ALG
Firmware has been updated to V1.0.3.102_1.0.48
I don't have the networking knowledge to make sense of the other Netgear articles (which have broken internal links) e.g. https://kb.netgear.com/966/Troubleshooting-VPN-passthrough-for-home-routers
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 6
Highlighted
NETGEAR Moderator
Re: RAX80 - Aruba VPN fails
Hi MikeWWW,
Have you had a moment to check in with your employer for any input regarding this?
Christian
Message 2 of 6
Highlighted
I tried that first, but because it appears to be a problem external to their control ie this router, it's not something they can handle. The VPN services thousands of other network users, so if they'd encountered this it would be documented.
Message 3 of 6
Highlighted
NETGEAR Moderator
Hi Mike,
And have you had a moment to contact our support team? If not, please send me a private message with your contact info. I can assist with our support team reaching out.
Christian
Message 4 of 6
Highlighted
No - your support page says that support is only available for the first month or so. My router is now a year old.
Message 5 of 6
Highlighted
Netgear's support expires after six months. The extended support options for home users are only available to US customers.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 283 views
  • 0 kudos
  • 2 in conversation
Announcements
