K8rain's avatar
K8rain
Follower
Jul 30, 2021
2.5 and 5G lights not on (R7000P)
Only lights on my router are the on and the internet light…. Where did the other ones go??? I obviously have no internet. HELP!
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Maybe someone, or something (cats have done this), turned off the wifi with the wifi on/off switch on the top.
    You can still plug things into the Ethernet ports on the back.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
