- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC2300 Nighthawk - Where to change NAT type to Open
- Mark as New
- Bookmark
- Subscribe
- Permalink
I couldn't find the Model type in the list, so hopefully this isn't some bootleg model, but in following all of the directions online regarding the routerlogin.net process for changing NAT type, I cannot replicate them. All of them mention a maintenance area I do not see on the attached devices screen, and all of them mention a protocol forwarding I don't see on the attached devices screen. I checked in the advanced menu as well, and cdo not see either of those options. Can someone assist?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC2300 Nighthawk - Where to change NAT type to Open
Hi @HeliumB, the link below may help out.
https://kb.netgear.com/24290/How-do-I-add-a-custom-port-forwarding-service-on-my-Nighthawk-router
Dexter
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can also set NAT Filter from Secure to OPEN under Advanced tab/WAN setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You won't. The list is out of date, but there is no such thing as an AC2300. That's a wifi speed indicator.
The model number is probably the R7000P, which is in the drop down ;list.
It is usually better to tell people what you want to achieve rather than what you are doing.
Why do you want to change the NAT type? You are trying to fix a problem? To get something to work?
There may be better ways of getting there.
It can also help to tell people what else is on your network.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
