HemD's avatar
HemD
AC3000 Model R7900 Factory Reset
I have tried to factory reset the AC3000 Router several times and I still cannot access the router by using the default password. Is there anything that I need to do to access the router using the factory default password?
Thanks.
  • plemans's avatar
    When you're pushing and holding reset, are you holding for up to 30 seconds while its powered on?
  • plemans's avatar
    also, its case sensitive. All lower case.
    login: admin
    password: password
    • HemD's avatar
      HemD
      Thank. Yes I did hold reset button pushed in for 30 seconds with no success.
      • plemans's avatar
        have you tried a different device?
        Also, make sure any password managers are disabled.
        Also try different browsers
