cambocac
Jun 10, 2018Aspirant
AC3200 TriBand - LAN & WIFI Issue
Have been having issues with this router for some time now. My connection is supposed to be 400 mbps down and am only getting 70-90mbps via Direct and/or Wifi. Have replaced the Cat5e cabling, Contacted spectrum and it always points back to the router. I have factory reset the device a few time now and still have the same results. Firmware updated 1.0.4.18 also. I would appreciate any help you guys can provide!!
If QoS is turned on, turn it off and see if that helps. Likewise the traffic meter.
- cambocacAspirantQoS and WMM are turned off as well
